I have made several PagerDuty-Jira integration connections successfully, except for my latest attempt. I cannot tell what I’m doing wrong.
All I get is this error message when creating a test issue: “JIRA test failed: JIRA was unable to process the request using the given parameters”
The only thing that would make this connection unique is that the one Jira issue type used in this project is “Bug”, and there are no priorities set up for it.
Also, the Jira project has “Summary” and “Description” as required fields.
Would you have any advice?
Thanks!
